Use this function to design deflecting islands along any selected reference line.
MOUS_ICO Toolbar: Not available from the ToolbarMOUS_ICO Menu: Road > Intersection Tools > Deflecting Islands…
The dialog Deflecting Islands will pop up.
Use this button to select the reference lines (primary and secondary). Deflecting island will be designed and drawn to a secondary line. The parameters can be defined before selecting the reference lines or after selecting the reference lines.
Command prompts for:
* Select secondary road centreline, Deflection Island's location (bottom point):
* Pick centreline primary road, left arm of intersection as seen from the deflection island:
A preview of the deflecting island will be drawn in AutoCAD.
Use this function to edit previously designed deflecting islands. To edit select the island line, not the curbstone line.
Use this button to select distance from top right rounding radius to edge line.
Use this button to select distance from top left rounding radius to edge line.
Use this button to select the bottom point of the deflecting island.
