Novapoint Road Library
Delete Alignments in Drawing
04-19-2021 11:58
Use this function to delete several Novapoint and CAD lines at once.
MOUS_ICO Toolbar: Not available from the Toolbar
MOUS_ICO Menu: Road > Draw Horizontal Alignment > Delete Alignment(s) in Drawing
Command prompts for:
Pick a line, arc, polyline/Undo:
MOUS_ICO Select the objects and finish with the right button of the mouse or the key Return.
Note:
The command UNDO can be used to bring back the deleted alignments.
