View Entry
Back to Library
Trimble Connect for Windows 1.01 | Release Notes | June 14 2016
Recommend
12-20-2016 19:27
Content Manager
Trimble Connect Windows v1.1
New Features
Trimble Connect for Desktop supports now 16 languages:
English en-US
Chinese (simplified) zh-Hans
Chinese (traditional) zh-Hant
Dutch nl-NL
French fr-FR
German de-DE
Italian it-IT
Japanese ja-JP
Korean ko-KR
Spanish es-ES
Russian ru-RU
Brazilian Portuguese pt-BR
Danish da-DK
Swedish sv-SE
Norwegian nb-NO
Finnish fi-FI
Project library can be now filtered by the project server location.
File tree supports now the following operations: Rename/remove file/folder, rearrange file/folder structure by drag and drop, drag and drop files from Windows explorer.
ToDo list supports now grouping, sorting and filtering.
A button that opens the project in web browser has been added to the data tab.
Trimble Connect for Desktop now supports visualization of measurements created from Trimble Connect for Web.
Improvements
Some users experienced issues when trying to login Trimble Connect for Desktop in an environment where proxies were required. This has now been fixed by including a default proxy setting in the application's configuration file.
The ToDo related icons have been updated.
Usability of the transparency slider in the 3D view has been improved by changing the slider path background.
View creation has been improved. Now the view name needs to be defined before the view is synchronized with the server.
"When a model version was updated after a clash check, the related clashset and clashes were completely hidden from the clash list. This has now been changed so that clashes with outdated model version are shown as red in the clash list. If one modelElement related to the clash is outdated and one is not, clash is shown as gray. Red items cannot be selected and they are not visible in the 3D view. Gray items can be selected and they have semitransparent clash symbol in the 3D view."
Fixes
Fixed an issue where the user was not able to continue offline usage after a certain period of time.
Fixed an issue where project couldn't be created if the name contained any special characters. Now special characters are removed from the project name while project creation.
Fixed an issue where clip planes saved in views were not shared correctly.
Fixed an issue where project name change in offline mode was not updated correctly.
Fixed an issue in ToDos due date that caused the date be one day too early.
Fixed an issue where the object selection and visibility states in views were not interpreted correctly between Trimble Connect for Desktop and Trimble Connect for Web for .skp, .igs and .step files.
Fixed an issue where Trimble Connect for Desktop crashed occasionally when a view containing markups was restored.
Fixed an issue that occasionally prevented clash sets to be updated.
Fixed an issue which occasionally prevented recovering online connection satus correctly.
Fixed an issue which occasionally prevented a clash to be attached to a ToDo.
Fixed an issue where clash symbol states and associated object visiblity was not working correctly.
Update
The End User License Agreement (EULA) has been updated.
Ville Kyytsönen
03-02-2017 01:33
Link to the (updated) EULA would be very helpful.
