Use this command to disconnect selected land use areas. The hatches are removed and the land use text and topology lines are left in the drawing.
MOUS_ICO Menu: Landscape > Land use disposal > Disconnect One or Several Land Use AreasMOUS_ICO Toolbar: Land use disposal: Disconnect One or Several Land Use Areas
Use this function when you want to edit the lines in the drawing. The hatches are removed so that you easily can edit the lines. The areas can be easily connected with Connect one or several land use areas again after editing the lines.
