Novapoint Road Library
Intersection Between Two Alignments
04-19-2021 11:44
Use this function to calculate the intersection angles between two lines, which can be alignments in the database (Quadri model) or CAD 2D/3D lines/polylines/arc elements. The function calculates and lists the mathematical details related to the intersection of the selected elements.
  • The intersection of the two lines/alignments in the plan must use this function (both the alignments need not have the same elevation at the intersecting point).
  • The result summary can be copied to the clipboard and from there to other programs, such as Notepad, Excel, or Word.
  • More over the function facilitates to offset the selected lines and analyze.
The analysis will be done for Chainage, Northing & Easting of intersection points, Bearing, Gradient, Horizontal offset, Element number, Element type, and Elevation difference at intersection points in plan (selected lines might not intersect in 3D).
Procedure
MOUS_ICO Toolbar: Alignment Analysis: Intersection between two Alignments Intersection between two Alignments
MOUS_ICO Menu: Road > Alignment Analysis > Intersection between two Alignments…
MOUS_ICO Ribbon: Alignment Analysis: Intersection between two Alignments Intersection between two Alignments
The dialog Intersection between lines will pop up.
  • The upper part of the dialog has fields Master line, Second line, buttons Ellipse and Select, and Reset.
  • Use the button Ellipse to select the alignment from the Quadri Model and the button Select to select the CAD elements.
    • When pressing Ellipse, the dialog Quadri Lines pops up where all alignments available in the terrain model are listed. Select the desired alignment.
    • When pressing Select user is allowed to pick the elements from the CAD drawing. Follow the command prompt.
  • Offset: Specify horizontal offset for each line if necessary.
  • Options: This button opens the dialog where users can specify the relation between the coordinate system in the terrain database and the current UCS in CAD.
  • The program automatically calculates the intersection data as soon as both lines are defined.
  • A message appears on the command line if the lines do not intersect.
  • The results are listed in the incorporated spreadsheet in the dialog Intersection between lines and should be self-explanatory.
  • Reset: Use this to clear the dialog
  • Draw: Use this button to insert annotation for included angle and the chainages of the lines/alignments at the intersection.
    • The alignments are to be drawn before calling this function to use this option.
    • Click this button and follow the command prompt.
Pick where to locate label:
MOUS_ICO Pick the location for the label (chainages of the intersecting lines/alignments at the intersection)
Pick where to locate angle:
MOUS_ICO Pick the location for the intersection angle
Figure: Illustration for Label at Intersection of Lines/Alignments
Illustration for Annotations at Intersection of Lines/Alignments
A= Label for included angle B= Label for chainages of intersecting lines/alignments at the intersection
C= Alignment/Line D= Alignment/Line
