Product Update - 12-17-2020 | Navisworks Support in Trimble Connect for Windows (BETA)
12-16-2020 14:32
Upload & View Navisworks Files
It is now possible to add Navisworks (.NWD & .NWC) model files to the project and view them in 3D using the Connect for Windows application.
The Navisworks model viewing is released as a BETA feature
In this stage of the BETA period, the NWD & NWC file formats support plain 3D viewing only. The files cannot be used in other workflows, like for example in creating Views, ToDos or Clash checks. Also, there may be some models that are not rendered correctly or some property data may be incomplete.
Step 1: Upload Your File
  1. Download the latest version of Trimble Connect for Windows (version 1.11 or newer) from the Trimble Connect App Store and install on your computer
    Note: if you already have Trimble Connect for Windows on your machine, verify you are using the latest version. Update if necessary. Version 1.11 or later required.
  2. Sign in to Trimble Connect
  3. Open your project
  4. Click Add file
    Alternatively: drag & drop a .NWD or .NWC file from Windows Explorer
  5. Using the file explorer, navigate to a Navisworks (.NWD or .NWC) file and select it
  6. Click the View button
  7. Once the file has been processed it will appear in the 3D view.
  8. Upload the file to cloud
Step 2: View the File on the Web
  1. Go to the Connect for Browser 3D Viewer in https://3d.connect.trimble.com
  2. Select a model file by clicking it in the Models panel
  3. To view the file, click the Load model icon
    Note: If the download is complete but you are not seeing your model, it may be because of the zoom level. In the Overflow Menu - select the option Fit to View
    03-27-2025 12:08
    It would be good if Trimble would provide a document that shows the best way to avoid NWD file loading issues into Connect. Is there a max number of supported layers, individual features (entities), etc.? I was supporting a customer earlier and couldn't recommend what the best thing to do was, as I don't run Navisworks. It also would seem that any layer purging/auditing has to happen upstream from Navisworks. How to purge unused material or elements in Navisworks. In this particular case, I was able to upload the NWD as is to Trimble Connect for windows (latest version) but it took nearly 15 minutes and was quite sluggish. It simply fails when attempting to upload to Trimble Connect on the web. It also errors out when trying to import into Trimble Realworks (latest version). Again, a document on what Trimble connect requires for proper rendering and usage of a NWD file would be nice!
    06-06-2024 04:31
    hi, can you advise if this feature is supposed to allow .nwc files to be brought into Tekla Structures (2023 sp10) as an overlay model?
    01-19-2021 13:47
    I have the latest version of Trimble Connect installed, but I am still unable to view a 10MB NWD file. Are there any other solutions that I can try to view an NWD file?
