Draw 3D Object along an alignment
08-11-2021 07:32
What
With this function you can draw 3D objects along an alignment.
Where
How
The following method is used:
  1. Start the function
  2. Select trench
  3. Add horizontal info of which line the objects are to be drawn along
  4. Click OK
  5. Add values
  6. Select which library and what parts to use under Block Name
  7. Auto fill to add more part in a given distance. Default values will be used. You also do this manually
  8. End with Draw
