I am trying to draw a table in TBC with the information based on a data table and I don't want to simply draw the table using line and Mtext.Are there any methods that I can use create a custom table? I came across the below methods but without any proper documentation it's really hard to work them out-LableTableCell-LabelTableColumnsBase-LabelTabelColumns-LableTableEntityBase-LableTableRowBase-LableTableRowsThis was used to be an easy task in AutoCAD, goes like this
public void addRow(String[] data) { // Use a nested loop to format each cell for (int i = 0; i < data.Length; i++) { ParseOption s = new ParseOption(); Cells[rowCount, i].TextHeight = 1; Cells[rowCount, i].SetValue(data[i], s); } GenerateLayout(); Transaction tr = doc.TransactionManager.StartTransaction(); using (tr) { BlockTable bt = (BlockTable)tr.GetObject(doc.Database.BlockTableId, OpenMode.ForRead); BlockTableRecord btr = (BlockTableRecord)tr.GetObject(bt[BlockTableRecord.ModelSpace], OpenMode.ForWrite); btr.AppendEntity(this); tr.AddNewlyCreatedDBObject(this, true); tr.Commit(); } }
