Novapoint Road Library
Draw Contour Marks on 3D Lines
04-19-2021 16:07
Use this function to draw contour marks on a selected 3D line at desired contour interval.
MOUS_ICO Toolbar: Elevation Tools:  Draw Contour Marks on 3D-Line
MOUS_ICO Menu: Road > Elevation Tools > Draw Contour Marks on 3D-Line
Tip:
Shortcut to this function (in case the 3D-line is a Novapoint entity):
MOUS_ICO Toolbar: Novapoint Base:  object_menu
Command prompts for:
Select an Entity:
MOUS_ICO Pick a 3D-line
MOUS_ICO Select the flyout menu option Draw Contour
Command prompt for:
Contour spacing <5.00>:
KEYB_ICO Define the contour interval (metre), at which contours are to be marked.
Point to a line, arc, or polyline:
MOUS_ICO Pick all the 3D lines and confirm the selection with the key 'Return'
