Use this function to do the following:
The above three are the options of this function and the marked (check box) option(s) will be executed.
MOUS_ICO Toolbar: Not available from ToolbarMOUS_ICO Menu: Road > Draw Horizontal Alignment > Draw Extra Chainage Points from Reference AlignmentMOUS_ICO Ribbon: Road > Draw Horizontal Alignment > Draw Extra Chainage Points from Reference Alignment Draw Extra Chainage Points from Reference Alignment
Command prompts for:
Pick base line:
MOUS_ICO Select the line (alignment or CAD line/polyline/arc), on which extra chainage points are to be calculated and drawn.
Pick reference line:
MOUS_ICO Select the line (alignment or CAD line/polyline/arc), from which the extra chainage points and offset are to be calculated.
The dialog box Draw Extra Chainage Points from Reference Alignment will pop up.
The options to draw the extra chainage points are to be marked at this field. The corresponding setup for the extra chainage points can also be customized. The available options are as follows:
Mark the check box to save the data of the extra chainage points being inserted to a text file.
