This function draws selected alignment(s) or/and sets a drawing style. This function facilitates to select alignment(s) from:
MOUS_ICO Toolbar: Draw Horizontal Alignment: Draw Horizontal AlignmentMOUS_ICO Menu: Road > Draw Horizontal Alignment > Draw Horizontal Alignment…MOUS_ICO Ribbon: Draw Horizontal Alignment: Draw Horizontal Alignment Draw Horizontal Alignment
The dialog Draw Horizontal Alignments will pop up.
Select the alignment to be drawn using any of the options Object, Pick from Drawing, and File.
The current drawing scale is displayed. To change the drawing scale, exit this function and run the function drawing_scale.
Use this field to define the rotation of the label/annotations depending on the angle at which the drawing is viewed.
Select the unit of angular measurement from the drop-down menu.
Select the desired drawing style from the pull-down menu, which lists all the pre-defined and user-defined drawing styles for the alignment.
Use this () icon to filter the available styles in the drop-down list (customize the pull-down menu).
Use this () icon for a preview of the active drawing style.
