Use this function to draw the longitudinal profile from the Quadri model for the desired (source) line.
The source line can be:
If the source line is also having its vertical geometry attached, the vertical profile shall also be presented.
MOUS_ICO Toolbar: Draw Longitudinal Profile > Draw Longitudinal Profile from Quadri ModelMOUS_ICO Menu: Road > Draw Longitudinal Profile > Draw Longitudinal Profile from Quadri Model…
MOUS_ICO Menu: Railway > Draw Longitudinal Profile > Draw Longitudinal Profile from Quadri Model…
First, select which alignment task you want to work with.
The dialog Select Horizontal Alignment will pop up.
Step 1 - Source Line, Calculation Settings, and Sub-Surface Information
Define how to calculate the terrain profile
Click the button Next to define the presentation settings and to select the additional features that are to be included in the longitudinal profile. The dialog Draw Longitudinal Profile from Quadri Model will pop up.
Step 2 - Presentation Settings and Additional Features
The active Quadri model, start chainage, and end chainage of the source line will be displayed at Terrain Design Task. To change the Quadri model, exit the function and run the function Select design task.
