Novapoint Road Library
Draw Matchlines Along Line
04-19-2021 13:12
Use this function to draw matchlines.
MOUS_ICO Toolbar: Not available from the Toolbar
MOUS_ICO Menu: Road > Drawing Generator > Plan and Profile > Draw Matchlines Along Line
MOUS_ICO Menu: Railway > Drawing Generator > Draw Matchlines Along Line
Command prompts for:
Pick a line, arc, polyline:
Select the line, along which matchlines are to be drawn.
The dialog Draw Matchlines along Line will pop up.
Alignment info
  • From/To Chainage: Define the section of the select line, for which match lines are to be drawn.
    • By default, the entire section of the selected line will be considered.
  • Chainage Interval: Define the interval for the matchlines.
  • Number Definition: Use this button to define the number format for the chainage label, which will be inserted at the matchlines.
    • The dialog Number Definition will pop up with this button.
    • For further details, refer to the topic Number Definition.
Drawing Style
  • Two types of pre-defined labels are available for matchline. Method 1 and Method 2.
  • Mark the desired radio button.
  • For method 2, a triangle is the addition.
    • Define the height and width of the triangle at the respective fields.
Annotations
The matchline label consists of annotations. Define the text for these annotations.
  • Layer: Define the layers for the matchlines annotations.
  • Font: Select the desired font style of the annotations of the matchline labels.
    • The dialog Fonts will pop up with this button.
    • For further details, refer to the topic Fonts.
  • Line Length: Define the length of the leader line.
  • Color: Click the color field to change the color of the leader line.
