Draw multiple longitudinal profile
07-16-2021 03:53
What
  • Use this function to draw multible longitudinal profiles. This is very helpful if the trench is long. To draw a single longitudinal profile use Longitudinal profile
  • It is important to know that the generated profile will show the model at the time it was generated. Use update longitudinal profile to update if the model is modified.
  • The active water and sewer project is referred as simply model and the trench of the model is referred as baseline.
  • Scale in the Novapoint ribbon controls indicated scale
  • Drawing layout will be according to the configuration
  • Go to the configuration, settings and Presentation longitudinal profile... to change layer names, layer colors, line types, etc...
Where
You can find the function in the following location:
How
Use this function the following way
  1. Start the function
  2. Select trench
  3. Change insertion point of the first frame
  4. Edit settings
  5. End with draw
    • Update - The profile can be updated if the model is modified
      • Calculate the model and run the function 'Update Longitudinal Profile from WS Model'
