View Entry
Back to Library
Draw multiple longitudinal profile
Recommend
07-16-2021 03:53
Eirik Braaten
What
Use this function to draw multible longitudinal profiles. This is very helpful if the trench is long. To draw a single longitudinal profile use
Longitudinal profile
It is important to know that the generated profile will show the model at the time it was generated. Use
update longitudinal profile
to update if the model is modified.
The active water and sewer project is referred as simply
model
and the trench of the model is referred as
baseline.
Scale
in the Novapoint ribbon controls indicated scale
Drawing layout will be according to the configuration
Go to the configuration, settings and
Presentation longitudinal profile...
to change layer names, layer colors, line types, etc...
Where
You can find the function in the following location:
How
Use this function the following way
Start the function
Select trench
Change insertion point of the first frame
Edit settings
End with draw
Update - The profile can be updated if the model is modified
Calculate
the model and run the function 'Update Longitudinal Profile from WS Model'
