Use this function to generate profile frames along the selected line. The profiles frames thus obtained are further used in the function Autodraw Plan and Profile.
MOUS_ICO Toolbar: Not available from the ToolbarMOUS_ICO Menu: Road > Drawing Generator > Plan and Profile > Draw Profile Frames along Line
MOUS_ICO Menu: Railway > Drawing Generator > Draw Profile Frames along Line
Command prompts for:
Pick a line, arc, polyline:
Select the centreline/alignment along which profile-frames are to be drawn.
Pick lower-left corner for the first vertical alignment frame <0.00,0.00,0.00>:
Pick the insertion point from the AutoCAD screen or define the insertion point at the command line.
The plan-frames will be drawn as shown in the illustration diagram.
