Use this function to draw a plan drawing of the road model (all the surfaces that were used in road design).
This tool will present the calculated road model data only. Set the road model cross-section interval to a denser value, e.g., every 1.0m, to ensure a nice presentation of road models at steep horizontal curves. Road models based on denser intervals will also result in a more detailed quantity calculation.
MOUS_ICO Menu: Road > Draw Road Model…MOUS_ICO Toolbar: Road: Draw Road Model…
Click the button Draw to execute the function.
The road model boundaries defined in road surfaces and the property boundaries defined in property boundaries can be drawn to the CAD drawing
Contours for the surfaces of the road model can be drawn to the drawing file.
