Use the following procedure to generate a superelevation table in AutoCAD.
MOUS_ICO Menu: Bridge Cross Section Draw Super Elevation TableMOUS_ICO Toolbar: Cross Section Draw Super Elevation Table
The dialog box 'Select Section' will pop up, which lists all the section effected to super elevation. Select the station from the list for, which super elevation table is to be generated. Click OK to finish.
Tip: You can select multiple rows using the key Shift and Ctrl.** On the command line you now have to specify the table header text and finally you must pick the location on the drawing for the lower-left corner of the table. Command prompts for:
Table heading text:
Give a name for the Table being inserted.
Table lower-left corner:
Pick the insertion point for the table. Lower left corner is the insertion point.
