Use this function to draw the terrain cross-sections along the desired (source) line. The cross-sections will be drawn in one column. The source line can be:
MOUS_ICO Toolbar: Draw Cross-sections: Draw Terrain Cross-sectionsMOUS_ICO Menu: Road > Draw Cross-sections > Draw Terrain Cross-sections…
The dialog Select Horizontal Alignment will pop up.
Step 1 - Source Line, Calculation Settings, and Subsurface Information:
Define how to calculate the terrain profile
Click the button Next to define the presentation settings and the additional features that are to be included in the cross-sections. The dialog Draw Cross-section will pop up.
Step 2 - Presentation Settings and Additional Features
The active Quadri model, start chainage, and end chainage of the source line will be displayed at Quadri Model Info. To change the Quadri model, exit the function and run the function Select design task.
