View Entry
Novapoint
Civil Construction & Infrastructure Solutions
Back to Library
Drawing Longitudinal Profile
Recommend
05-31-2021 07:01
Stefan Petersson
If you have trouble drawing out the longitudinal profile please try these helpful tips:
Drawing Style is missing key elements
Answer:
Try using a different drawing style or drawing from a different road model. Is it still the same problem?
Check if any of the layers in the drawing is turned off or frozen?
Try running
Reset user settings
Cannot draw the whole road model
Answer:
Is the road model build for the whole stretch you want to draw?
Missing terrain when drawing out the longitudinal profile
"The terrain line is missing but I still have values for terrain elevation in the bottom half of the frame."
Answer:
Try turning on
Simplify terrain cross-sections
in the roadmodel settings. Then rebuild the model.
To access this:
Roadmodel settings from Design ribbon or Model > Settings in Classic roadmodeling tool
Go to
Terrain Boundaries
Go to
Advanced
Turn on
You could also try to vary the horizontal and vertical
tolerance
