Quadri
Easy Access Settings
03-24-2021 21:03
MOUS_ICO Server > Settings > Easy Access Settings
On this page, you have to register the Trimble ID (3.0 or newer) or Vianova ID (2.0 or older) and password to be able to enable projects in the server for Easy Access.
If the server is set up with SSL, you must register the domain connected to the SSL certificate in the IP/Domain text box.
