Novapoint Landscape Library
Edit Point Elevations...
04-07-2021 19:49
Use this tool to adjust the elevations of selected point elevations and all connected slope arrows will update instantly. The value you give is added to the elevations of all the points in the selection set.
MOUS_ICO Menu: Landscape > Elevation tools >Edit point elevations…
MOUS_ICO Toolbar: Elevation tools –  Edit point elevations…
Working procedure
Start the function and the command prompts:
Select one or more point elevations to adjust:
Select one, several or all (by window, for instance) point elevations and press 'Enter'.
The command prompts:
Enter a value to adjust point elevations by:
Type the value that shall be added to current elevations and press 'Enter'.It is possible to enter positive (increases the height) or negative value (decreases the height.)
Tip: It is also possible to use the mouse wheel to roll up/down the elevations instead of typing in a numeric value.
About point elevations in Novapoint Landscape
  • Point elevations are blocks with insertion points in the “+”-sign. The z-value for the block will always be equal to the written text.
  • The leveling tools are a set of functions working within the dwg file as well as interacting with the active terrain model. Editing and calculating point elevations must be done by using the leveling tools only! It does not work to use AutoCAD-functions like move, copy, copyclip/paste, properties, attribute editor, etc. in order to edit or manage the appearance of point elevations in Novapoint Landscape.
