Novapoint Terrain Library
Edit Slope Arrow
04-12-2021 12:49
The function 'Edit Slope Arrow' adjusts the slope of the selected slope arrow and updates the related points and arrows.
MOUS_ICO Menu: Terrain > Elevation tools >
Edit slope arrow…
MOUS_ICO Toolbar: Elevation tools- Edit slope arrow…
Working procedure
Start the function and the command prompts:
Select slope line to edit:
Select a slope arrow to edit
The command prompts:
Choose reference point elevation:
Select the reference point elevation which will keep its elevation and press 'Enter'
Enter new slope percentage:
Enter the new value of sope percentage and press 'Enter.' Opposite point elevation will now be updated and all connected slope arrows will also be adjusted.
Tip:
It is also possible to edit the slope value by rolling up/down the mouse wheel instead of typing in a numeric value.
About point elevations in Novapoint Terrain
  • Point elevations are blocks with the insertion point in the “+”-sign. The z-value for the block will always be equal to the written text.
  • The leveling tools are a set of functions working within the dwg file as well as interacting with the active terrain model. Editing and calculating point elevations must be done by using the leveling tools only. It does not work to use AutoCAD-functions like move, copy, copyclip/paste, properties, attribute editor, etc. in order to edit or manage the appearance of the point elevations
