Novapoint Bridge Library
Elevation Annotation
04-05-2021 14:16
The function customizes the Elevation Annotation.
MOUS_ICO Menu: Bridge Tools Elevation Annotation
MOUS_ICO Toolbar: Tools Elevation Annotation
The dialog box 'Elevation Annotation' will pop up.
Direct Annotation (Default)
The elevation values are written directly on the drawing.
Alpha Numeric Annotation
Writes a reference number to the coordinate point on the drawing and the coordinates are to be read from the Elevation Table, which is generated from the tool 'Elevation Table'.
Arabic Numeric Annotation
Writes a reference Arabic numeral to the coordinate point on the drawing and the coordinates are to be read from the Elevation Table, which is generated from the tool Elevation Table'.
Roman Numeric Annotation
Writes a reference roman numeral to the coordinate point on the drawing and the coordinates are to be read from the Elevation Table, which is generated from the tool Elevation Table.
Start value
If alphanumeric, Arabic numerals, or Roman numerals are used, you will have the privilege to select desired start number. The program automatically calculates the first free number in the drawing.
Draw reference line (default)
Draws a line to mark the elevation point. See the above four images, which are having reference lines (small horizontal lines at the annotation originating point).
Choose UCS
Shows all the stored UCS in the drawing. The current UCS is the default. Choose which UCS you want the elevation to be written and calculated in. The elevation is always calculated in the UCS you have chosen as the current. The elevation equals the Y coordinate in the current UCS.
The UCS name is stored together with the reference symbol in the drawing. When you later draw a table, the reference elevation point will be calculated according to the stored UCS.
Draw annotation
Tip: Adjust the SNAP setting to fit your actual type of point.
Command prompts for:
Pick the coordinate point or enter a new symbol name &lt5 >:
Pick the coordinate, for which coordinate details are required.
Pick text point:
Pick the second point of the leader line.
Pick the coordinate point or enter a new symbol name &lt2 >:
If the reference numeral is to be changed enter the new numeral or pick the second coordinate, for which coordinate details are desired. Continue the same process till all the coordinate points for which the coordinate details are desired, are selected. The function continues to be active after you have written the annotation text for all the desired points. This means that you can continue to pick coordinate points on the drawing and write annotation text without choosing the Elevation Annotation function again. Finish with the key Return or ESC or the Right button of the mouse.
The Elevation Annotation is written when you pick the text point.
The annotation will be drawn on a new layer B_Symbol_0 (Novapoint creates).
If you choose an annotation option other than Direct, you can enter a new value directly on the command line. It does not matter if you type in a letter or a digit. The program will check if the value already exists and try to increase the value for the next symbol. If you choose to type a Roman numeral, you have to start with the letter R.
Legal values
Examples of legal values given on the command line are:
Normal values that will be increased automatically are: 1, 234, A, X, RI, RXX
Values that will not be increased automatically are: a, AB12, 12AB, RIX, ab
If the program cannot increase the value for the next symbol, you will get a message.
