View Entry
Quadri
Civil Construction & Infrastructure Solutions
Back to Library
Error when opening Quadri model
Recommend
05-26-2021 02:40
Stefan Petersson
I get this error message when I try to open the model. What can I do?
PIC
Answer:
Please do the following:
Make a copy of the file named "YOURMODELNAME.zQuadriModellBackup"
Paste it into another folder
Right click and rename the file, call it "YOURMODELNAME.zip"
Now this is a regular zip file. Unpack it.
Go into Novapoint and open the new model
PIC
Answer:
It is not really an error message, the message just says that you have to point to the correct Feature Catalogue.
You can find it by going to this folder:
C: \ Program Files \ Trimble \ Novapoint \ YOUR VERSION \ Configuration \ Default \ FeatureCatalogues
In this case it's quadri_1933_1.28.dat. Therefore, you need to point to quadri_1933_1.28.dat at the bottom of the folder.
PIC
Answer:
This means the server on which you have saved your project must be mapped with a letter. In your case, it probably looks something like this:
\\Server\Project\
. For Quadri for Windows to be able to load the project, it must look something like this: X:\Project
We strongly recommend a routine where everybody who works against the same server uses the same letter.
