Draw 3D pipes/manholes 3D from WS-model
04-16-2021 08:36
Draw 3D pipes/manholes 3D from WS model
What
Use this function to draw the pipes and manholes of the active Water and Sewer project to the current AutoCAD drawing in 3D.
  • The function uses the data from the Water and Sewer project, which means that the drawing reflects the latest update.
  • Pipes and manholes are being inserted into named layers.
  • The application creates new layers to AutoCAD.
  • Layer name describes the type, material, and diameter of the object.
  • Using this information it is possible to create a Virtual Map configuration for Water and Sewer project.
Where
How
  • The function draws the pipes and manholes in 3D.
