View Entry
Back to Library
How to import KOF file with WS-data
Recommend
08-12-2021 05:39
Eirik Braaten
Problem
This is a step-by-step solution on how to import KOF files correctly.
Solution
In Quadri, go to the insert ribbon and select Import Files
Write name and select subtask
Click Select Files.
Navigate to the SOSI-file and click Open. Remember to search for the correct filetype:
A new dialogue will open. Validate the coordinate reference system
Click on Select Rules
Click OK
Select conversion rule. The standard KOF_VA Ledningsnett is made specifically for water and sewer
Click OK
Click Preview. Check if every features are converted in Process info
End with Finish
