How to import SOSI with WS-data
08-12-2021 05:19
Problem
This is a step-by-step solution on how to import SOSI files correctly.
Solution
  1. In Quadri, go to the insert ribbon and select Import Files
  2. Write name and select subtask
  3. Click Select Files
  4. Navigate to the SOSI-file and click Open
  5. A new dialogue will open. Validate the coordinate reference system
  6. Click OK
  7. Click on Select Rules
  8. Select conversion rule. Standard (SOSI "version") usually do the trick
  9. Click OK
  10. Click Preview. Check if every features are converted in Process info. If not every feature are converted, there is more information here
  11. End with Finish
