View Entry
GeoSuite
Community Navigator
Back to Library
FAQs on Drawing
Recommend
05-03-2023 02:25
Artemis Karlatou
Question
Answer
1
CUI and customization
Customization and workspace switching is possible using the interface command under Manage. Here we can make our workspace with the selected ribbon and toolbars. Use the CUI or _CUSTOMIZE command in the Drawing and create your own workspace by drag and drop from the list. (Tutorial
https://www.graebert.com/blog/tutorial/work-spaces-ares/
2
Convert 3D to 2D (FLATTEN in AutoCAD)?
XtraTools > Modify - Tools(Command FLATTEN).
3
Convert 2D to 3D?
Function to be found in Road menu.
4
Print/Plot?
If we need to plot all the layout from one single drawing then we can use PRINT command to draw all the selected layouts.
5
Batch print?
Batch print is a method to plot all selected layout (Sheets) from different drawings (BATCHPRINT command).
6
Viewport (creating Layout)?
There are a lot of methods to set the correct view in a layout with the correct scaling and view port rotation. In Drawing we can use the Named View option to place the view in a correct scale and rotation. Double-click inside the selected viewports and select the Named View from the View type (Model,Sheet or default).
https://youtu.be/t4JNhxHIr4w
7
Match Properties?
Command PROPERTYPAINTER.
8
References
Command XR, XREF.
9
Change Background Color
Command OPTIONS > Background.
10
Use of AC short commands
Command OPTIONS > Aliases.
11
Window/Crossing/Lasso selection methods
Command PICKAUTO > enter value 5.
