View Entry
Novapoint
Civil Construction & Infrastructure Solutions
Back to Library
FAQ: When Support asks you to FIND THE PROJECTS SERVER.XML FILE
Recommend
01-03-2021 19:57
David Kosakowski
Find the projects server.xml file
To locate a downloaded projects server.xml file, you can either:
Alternative 1:
See in settings in Novapoint (Press “N” in upper left corner and then press “Settings”) where on your pc local worksets are stored.
Go to this file location and find a folder with the date you downloaded the workset.
Go into this folder, to a directory called “Job”, then “7” or some other number.
There you should find a folder with the project name.
In that folder, there should be a folder with the name MyProject.server.xml (where MyProject is your project name).
Alternative 2:
Open the project in Quadri for Windows (Novapoint)
Select the cloud symbol in the explorer window
Look at “Path” in the “Properties” window. This is the full path name to this QuadriModel file.
In the same location there is a file called MyProject.server.xml (where MyProjects is your project name).
