Quadri
When Support asks you to RESET USER SETTINGS
01-03-2021 19:45
RESET USER SETTINGS
To reset the user settings you do as follows:
  1. Go to the Start screen. Search for Reset User Settings and choose the correct Novapoint version that you want to reset.
  2. Check all the checkboxes to ON.
  3. Press OK in the dialog to start resetting user settings.
User settings are now reset.
The Reset User Settings function is also available from Windows Explorer normally located under C:\ProgramData\Microsoft\Windows\Start Menu\Programs\Novapoint {version number}\Tools
We recommend to backup user-defined files before running this function. This applies espesially to Road/Railway Drawing Style Setups you have created if these have not been placed a different spot then the default location outside of the Appdata-folder.
Using Reset User Settings can also revert company settings if you have your own setup done with the installation or the installation package at your office.
About Reset User Settings
Reset User Settings has the function that it deletes some application- and temporary files so that the software need to unpack these again. Often it is wise to run this function to clean up some of the system files if you experience error messages or irregularities in the software when you havn't reinstalled or done other changes and it worked “fine” the last time you tried it.
The reason for your error message or irregularity with the software may vary, but often may be caused by the files that Reset User Settings will handle and delete. The reason for the issue may be related to:
  • AntiVirus has messed with the files or set files in quarantene/deleted files
  • Previous crashes in the software has made some files unreadable/read only/empty/with wrong content.
  • Automatic cleaning tools on the local machine has deleted some files, but maybe not all, so that an unpack of files by the system is not triggered.
