Novapoint Road Library
Features Sent to Conversion Rule
04-18-2021 17:55
The features produced through the road model calculations are processed in the task according to the conversion rule. To be able to set up the conversion rule correctly we need to first know what data is produced.
By pressing CTRL+SHIFT+F12 inside Quadri we will start the Quadri.log file that is tracking all transactions in the background. This file is also available in the %TEMP%/Trimble/ -folder.
By looking through the file we will find content like:
Creating feature with attributes [LAYER, 0][VIPSSURFACENO, -1.01][VIPSSURFACENAME, NP21-roadmodel | -1.01 | V. Kjørefelt][ATTRSURFACENO, -1000100][VIPSSURFACEGROUP, ][TYPEID, V. Kjørefelt][TASKNAME, NP21-roadmodel][MEDIUM, 0][PROCESSHISTORY, Produced by Novapoint - Road][PHASE, ENUM:119115][RAILWAYSURFACETYPE, ][RAILWAYSLEEPERRIGHTSIDE, ]
Below this line we will find what kind of geometry type the feature is:
Feature created id -3 type 1 (LegacySurface)
What this tells us is that the road model has produced a surface with the following information:
Key Name Key Value Comment
LAYER 0
VIPSSURFACENO -1.01
VIPSSURFACENAME NP21-roadmodel | -1.01 | V. Kjørefelt
ATTRSURFACENO -1000100 A different way of writing road surface -1.01
VIPSSURFACEGROUP Not relevant
TYPEID V. Kjørefelt As this is a road surface we have isolated the road surface description
TASKNAME NP21-roadmodel Taskname the feature comes from
MEDIUM 0 This means the feature is located with 'Medium = On terrain'
PROCESSHISTORY Produced by Novapoint - Road The feature is produced by Novapoint Road
PHASE ENUM:119115 Is this designed or existing? Here it is saying it is a designed feature.
RAILWAYSURFACETYPE Not relevant for Road
RAILWAYSLEEPERRIGHTSIDE Not relevant for Road
From this information, the conversion rule will be able to map different parts of the information into features and attributes in the Quadri model.
