Tilos
Fixing the SVG to PDF Presentations Bug
08-18-2021 09:14
If you cannot create a PDF file using File > Create Presentations command, replace/add files on your computer by unpacking the zip below to the folder:
C:\Program Files (x86)\TILOS\Tilos111\svgtopdf
If you have a different installation path, they are located in the installation folder under the svgtopdf subfolder. Download the SVG_to_PDF.zip here.
Note: You may need to sign in/run as an Admin when extracting the zip file.
1 Files
13 Downloads
Attachment(s)
pdf file
Tilos Support Note - Fixing the SVG to PDF Presentations Bug.pdf   70 KB   1 version
Uploaded - 08-18-2021
