GeoSuite
Geosuite compatibility to other software
07-11-2023 07:39
If you are missing information about which AutoCAD and Novapoint version the different Geosuite versions are compatible with, check your Config Switcher in Start menu.
All the installed software (such as AutoCAD and/or Novapoint) that are compatible with the installed Geosuite version, will appear in the list under Cad version and/or Novapoint version respectively, as seen below:
OBS! Always control and correct accordingly the values and shortcuts to the follwing parametrers in the configuration file (.ini file): ACADVER, ACADEXE, ACADEXEA samt ACADEXEB
  • ACADVER = 19 for Autocad 2013/2014
  • ACADVER = 20 for Autocad 2015/2016
  • ACADVER = 21 for Autocad 2017
  • ACADVER = 22 for Autocad 2018
  • ACADVER = 23 for Autocad 2019
  • ACADVER = 24 for Autocad 2020/2021/2022/2023/2024
  • ACADVER = 25 for Autocad 2025
#Geosuite_Presentation
#Config_switcher
