GeoSuite
Geosuite Hatch Patterns in Autocad
05-03-2023 04:29
GeoSuite Toolbox uses a number of custom hatching patterns in AutoCAD. They are used for example in the AutoCAD-based version of GeoSuite Stability.
The patterns are not installed automatically and must be manually inserted into the AutoCAD design files (ACAD.PAT / ACADISO.PAT).
Where can I find the GeoSuite HATCH patterns?
GeoSuite hatch patterns (GeoSuite.PAT) are installed in the folder C:\Program Files (x86)\Vianova\Novapoint\GeoSuite\2015\CAD (or equivalent)
The file content looks like:
This should then be added at the end of the ACAD / ACADISO.PAT used by AutoCAD / Civil3D.
Where can I find ACAD / ACADISO.PAT
Give the command “Options” in AutoCAD to see the settings in AutoCAD. “Support file search path” are settings for the folders in which AutoCAD searches in - for example:
C:\Users\<user name>\appdata\roaming\autodesk\c3d 2016\enu\support
Locate the two files and add the entire contents of GeoSuite.pat at the end of AutoCAD * .pat.
There are instructions on how to configure AutoCAD on the Autodesk website - search on “Install Custom Hatch Pattern”
