GeoSuite
Geosuite Hatch Patterns in AutoCAD
04-16-2024 07:52
Geosuite Toolbox uses a number of custom hatching patterns in AutoCAD. They are used for example in the AutoCAD-based version of Geosuite Stability.
The patterns are not installed automatically and must be manually inserted into the AutoCAD design files (ACAD.PAT / ACADISO.PAT).
Where can I find the Geosuite HATCH patterns?
Geosuite hatch patterns (GeoSuite.PAT) are installed in the folder C:\Program Files (x86)\Trimble\Novapoint\GeoSuite\2020\CAD (or equivalent)
The file content looks like:
GeoSuite.PAT
This should then be added at the end of the ACAD / ACADISO.PAT used by AutoCAD / Civil3D.
Where can I find ACAD / ACADISO.PAT
Give the command “Options” in AutoCAD to see the settings in AutoCAD. “Support file search path” are settings for the folders in which AutoCAD searches in - for example:
C:\Users\<user name>\AppData\Roaming\Autodesk\C3D 2024\enu\Support
Locate the two files and add the entire contents of GeoSuite.pat at the end of AutoCAD * .pat.
There are instructions on how to configure AutoCAD on the Autodesk website - search on “Install Custom Hatch Pattern”
See also Webinar: Back to basics 2024-04-17
