Use this function to read the elevation of desired points from the current drawing and to insert annotation for the elevation.
MOUS_ICO Toolbar: Elevation Tools: Get Elevation from DrawingMOUS_ICO Menu: Road > Elevation Tools > Get Elevation from Drawing
Command prompt for: Pick a point for height markers:
MOUS_ICO Pick the point where elevation is required
Make use of snap modes for precise selection
The program reads the elevation from the active drawing and inserts an annotation for elevation.
