Getting started with the WS-module
11-08-2021 10:18
To be able to create and work with a WS model in the Quadri environment you need to first create a task in Quadri in order to connet quadri to your CAD software (where you design). Then you need to choose a configuration file and you are ready to design. Find out how you can get started with these steps here:
1. WS task in Quadri
2. Configuration file
Learn about WS configuration file
3. Design
Learn how to design WS
4. Export
Learn how to export data
5. Product library
Learn about the product library
The Initial Setup
Before we start you will need both Quadri and CAD installed. Note that if there are different versions of CAD-software available, be sure to check that you have a version that is compatible with the Quadri you are running.
In order to start working with the WS Module in Quadri you will have to have a license for the product. You also have to activate the module and “take” a license through the Module Loader.
To start the Module Loader you will have to start the CAD-software and go to the Novapoint ribbon.
The CAD-software needs to be started from the Quadri environment to be able to communicate with Quadri.
In the Module Loader select the WS Module and Start it. It is also practical to hit the button with the key to make sure you always have a license when you start the program.
With all this checked out you are now good to go.
