Novapoint Landscape Library
Give Contour Elevation (Z-value)
04-09-2021 10:04
Use this tool to elevate contour lines from 2D to 3D.
MOUS_ICO Menu: Landscape > Terrain design > Get contour elevation (z-value)
MOUS_ICO Toolbar: > Terrain design > Get contour elevation (z-value)
The command prompts for:
Select objects:
Choose the objects you want to give a new z-value. To get a quicker selection, type f for Fence and confirm with “Enter” to avoid having to pick one line at a time. If you choose to pick one line at a time, make sure you pick the lines rising from the lowest to the highest contour line.
First fence point:
If you have typed f for Fence, point at the first point on the fence line and confirm with “Enter”.
Undo/<Endpoint of line>:
Pick the next fence point or choose U to Undo your first chosen point. Confirm your choice with “Enter”.
5 found. Select objects:
Choose more lines if you need to or confirm by pressing “Enter”.
First contour line <0.00>:
Type the first contour lines height. The default value is 0. Confirm by pressing “Enter”.
Contour interval <5.00>:
Type the contour interval. The default value is set to 5. Confirm your interval by pressing “Enter”.
