MOUS_ICO Menu: Landscape > Terrain design > Give object(s) new elevation (z-value)MOUS_ICO Toolbar: > Terrain design > Give object(s) new elevation (z-value)
The command prompts for:
Select objects:
Choose the objects of which you want to change the z value. If you choose only one object you will automatically be able to type the z value (elevation) on the command line and you press “Enter” two times to finish. If you want to change more objects at the same time, use Window or Crossing.
Specify change point or [Properties]:
If you have selected more than one object to get a new elevation you have to type P for properties and press “Enter”.
Enter property to change [Color/Elev/LAyer/LType/ltScale/LWeight/Thickness/TRansparency/Material/Annotative]:
Type E for Elevation and press “Enter”.
Specify new elevation <varies>:
Type the objects new elevation. (All the selected objects will get the same elevation.)
Press “Enter” to finish.
