Use this function to interpolate elevations of break points of 3D lines (source line). The source line can be 3D Polyline or lines converted to 3D line using Create 3D - Line.
MOUS_ICO Toolbar: Elevation Tools: Height InterpolationMOUS_ICO Menu: Road > Elevation Tools > Height Interpolation
Command prompts for:
Select a 3D Polyline:
MOUS_ICO Pick the source line
The result is displayed at the command line. The source line will be redrawn with the interpolated heights.
Shortcut to this function (in case the source line is a 3D-line drawn using Create 3D - Line):
MOUS_ICO Toolbar: Novapoint Base: object_menu
Select an Entity:
MOUS_ICO Pick a 3D-line (source line)MOUS_ICO Select the flyout menu option Calculate Elevations
