Novapoint Noise Library
Heights
04-15-2021 14:42
#KH
Allows for setting heights for one or several calculation points.
Heights
List
Shows which heights/floors are defined for this calculation point. If there is a “-” in the Rel column, it means that this height is defined with absolute value. If there is a “-” in the Abs column, it means that this height is defined with a relative value. The value Floor has no practical importance.
Relative height
State the heights of the point as relative heights (relative to ground level).
Absolute height
State the heights of the point as absolute heights (meters above sea level).
Ground height
The calculated height in the XY point for the calculation point. The ground height of the calculation point is calculated from the terrain model and appears automatically in this field when you have selected exactly one calculation point, otherwise, it is invisible.
Nameless fields
These are corresponding with the list above. Enter values here to add or change information in the list.
New
Adds a floor with the information from the fields above.
Change
Changes selected height and/or floor number in the list to the values from the fields above.
Delete
Deletes selected height from the list.
