Trimble Connect for HoloLens 1.1 | Release Notes | Apr 23 2018
04-25-2018 11:19
New Features
Measurements in 3D Model Viewer (Premium Feature)
  • There are now three measurement modes available to a user through the ‘+’ button on the model viewer context menu.
    • Virtual surface to Virtual surface (model measurement)
    • Real surface to Real surface (mesh measurement)
    • Real surface to Virtual surface (mesh to model measurement)
Virtual to Virtual Measurement
  • Users can measure between two points on the virtual holographic model.
  • The gaze cursor will automatically snap to vertices in the model. Tap to start the measurement and tap again to complete it.
  • Users can create measurements on a real world surface in two ways:
    • Orthogonal measurements between a plane and a point
    • Measurement between two points
  • Users can measure the perpendicular distance between a plane and a point.
  • First select the plane and then pick the corresponding point opposite it.
  • Users can “free measure” between two points in the real world without any restriction to a certain axis.
Real to Virtual
  • Users can measure between a point in the real world and a point on the virtual model
    • This tool will first instruct the user to scan their environment to ensure a high-quality mesh.
    • The user will then select the point in the real world, followed by the point on the virtual model.
    • This mode is enabled only when the model is in an immersive 1:1 scale
App update notification
  • Users will henceforth be notified when an app update is available.
Improvements
Model Viewer - Context Menu - Auto Hide
  • The model viewer context menu will automatically render itself into a minimized state when not in use for more than 2 seconds.
    • The menu will expand to its original state when once again gazed upon by the user.
    • The menu will not minimize when it has been pinned to a surface.
Pivot-Based Alignment
  • The workflow, user interface, and ease-of-use of the pivot-based alignment tool have been improved.
Plane-Based Alignment
  • The workflow, user interface, and ease-of-use of the plane-based alignment feature have been improved.
  • Cautionary splash-screen has been added upon launch of the app.
  • Alert message is now shown when the QR scan fails.
  • This failure is generally due to no internet connection on the HoloLens or an expired QR code on the mobile device.
  • Application start splash screen has been updated.
Bug fixes
  • Application sometimes gets stuck when anchoring models
  • Model download fails for certain models forcing app restart
  • Hyperlink fixes in the ‘About’ section
  • ToDo - "Tap to Enter" text is not shown for "Type" when the user is the assignee of a ToDo
  • Todo - "Tap to enter " label is not shown for “Type” for an existing ToDo that does not have a type
  • Project browser - Project browser search results display lock images in UI when there are locked projects
  • Menu in a remote collaboration session sometimes deforms when a user performs a particular sequence of actions
  • Open source attribute in “About” page has been updated
