Quadri
How do I find my workset files
09-01-2021 03:44
If you need to do some operations on the workset files, you need to know where to find them. The easiest way is to open the workset, click the cloud symbol and look in the “Properties” window for the file path, which shows the full path to the QuadriModel file.
If you can't open the workset, but know where the binder file (*.npbinder) is, you can open that in a text editor and find the full path there.
If you don't find the binder file or don't know where it is, search your local disks for *.QuadriModel, and you should find all worksets.
