NETWORK LICENSING
In order to run your Novapoint application and retrieve a network license, a license server is required.
Trimble is using FLEXlm as our Network License Manager.
Usually, the demand on the server in itself is very low, so if your server/computer/VM can run the OS, there should not be any further need for extra resources on it.
It uses very little memory ,disk space and network resources.
The license manager run as a service, that uses 2 TCP/IP ports that the users must be able to connect against.
License server system requirements
The hardware and software requirements for the license server are:
| Software |
Requirement |
Notes |
| Operating System |
Windows 10 Windows 11 Windows 7 SP1 ESU Windows Server 2019 Windows Server 2016 Windows Server 2022 It is a best practice to run license servers on a server-based OS. |
Install network license manager
It is recommended to install and run the Novapoint License Service as a separate service. Merge the Novapoint License into other license services may cause problems.
Make sure the ZIP file not is blocked in Properties for the file.
Unzip file in the ZIP file to a locale folder.
Run the setup-Novapoint_License_FLEXlm_11-19×64.exe
On the Welcome to the InstallShield Wizard for Network License Manager page, click Next.
On the Custom Setup page, select the Novapoint_License feature to be installed on local hard drive. Specify the directory for installation of the network license manager. This directory will henceforth be referred to as [License Directory]. Click Next.
On the Ready to Install the Program page, click Install.
On the InstallShield Wizard Complete page, click Finish.
Start the network license manager
To start the network license manager
Start the lmTools program by selecting Start→Programs→Novapoint License 11.19→lmTools
Select the
Config Services tab.
Create a name for the Service Name, e.g. “Novapoint License Service”.
Set the Path to the lmgrd.exe file to be [License Directory]\lmgrd.exe.
Set the Path to the license file to be [License Directory]\License\[License File], where [License File] is defined freely, but must have .lic or .dat extension.
This is the file you receive from your Novapoint distributor. (See License file retrieval below).
Note: Make sure the filename is no more than 20 characters. Also use only standard characters (A-Z, 0-9) in the filename.
Set the file name and path to the debug log file to be [License Directory]\Log\[Log File], where [Log File] is defined freely, but must have .Log extension.
It is recommended to run the license server (lmgrd.exe) as a Window Service, thus tick the Use Services.
It is recommended to automatically start the network license manager (lmgrd.exe) when restarting the server, thus tick Start Server at Power Up.
Click Save Service.
Select the
Start/Stop/Reread tab.
Select the Novapoint License Server and click Start Server.
Exit from the lmTools program.
Before you install the license server, you need a valid license file. This can be retrieved by emailing your Novapoint distributor. In order to generate the license file, the Host Name and Mac address on the network card must be known.
Start up lmtools.exe on the license server. Select the System Settings tab where the system settings needed to generate a valid license file can also be found:
If the license server has more than one network card, make sure any virtual network cards are removed. Any other physical network card may be selected.
Your Novapoint distributor will need the following information to generate a valid license:
The product name, and quantity.
Server name (host name).
Host ID number (also called ”Ethernet Address”, ”Mac Address” or ”Physical Address”).
An email address where you want to receive the license file.
Redirecting the Novapoint client
Every Novapoint client needs to know about the license server. On the Novapoint client:
Click the Novapoint start icon to launch Novapoint
Enter the name of the license server and click Next. By doing this, FLEXlm will place the Server Name in the Registry, e.g. as this:
HKEY_CURRENT_USER\SOFTWARE\FLEXlm License Manager “NOVAPT_LICENSE_FILE” “@testpc4”.
There are many different options on how to assign the servername etc. For details, see the FLEXlm End User Guide.
Other licensing issues
As default the client machine will search for the license server using port 27000 trough 27009. If you want to specify a specific port number you will have to edit the license file on the License Server and make sure the client uses the same port number:
Edit license file on the License Server:
Open the License file in Notepad
Add the desired port number (eg. 27001) at the end of the first line:
SERVER testpc4 0050568220F8 27001
On the Client computer:
Open the registry editor to modify the FLEXlm License Manager registry setting:
[HKEY_CURRENT_USER\SOFTWARE\FLEXlm License Manager]
Modify the Novapoint License File key value:
NOVAPT_LICENSE_FILE=“27001@testpc4”
Make sure your firewall is configured to allow traffic on your desired port. This has to be configured on both server and client
It is not recommended to have more than one license file in the same folder.
Uninstall network license manager
To uninstall the network license manager
Start the lmTools program by selecting Start→Programs→Novapoint License 11.19→lmTools.
Select the Start/Stop/Reread tab.
Click Stop Server.
In the Control Panel, double-click Programs and features.
In the Programs and features window, select Network License Manager 11.19 in the list, and then click Remove.
(Delete the folder [License Directory] with all subfolders and files.)
Update registry. FLEXlm stores on all locations where a valid license has been checked out in registry.
HKEY_CURRENT_USER\SOFTWARE\FLEXlm License Manager\
Key: NOVAPT_LICENSE_FILE.
Delete the content of this key to reset license storage path.
General licensing matters
License file content
You should have received the license file with its valid content by email. Open the file in a text editor. The start of the file should look like the following:
SERVER TestPC 0008a1180ee4
VENDOR NOVAPT
USE_SERVER
INCREMENT NP_BASE NOVAPT 19.00 permanent 5 DUP_GROUP=UH \
ISSUED=17-May-2008 NOTICE="This license is usable only by \
Vianova Systems AS" SIGN="079B 473E 0154 D4C3 61E8 388D E48E A39E \
B79E 9598 49EA 680F 65CB 782C 81BC 1882 0E38 FD47 B1A3 B2DA \
9170 42D8 08B9 1336 8706 71D4 597D EDD1 28B8 547D"
INCREMENT NP_ROAD NOVAPT 19.00 permanent 5 \
VENDOR_STRING=DEPENDS:NP_ROAD>NP_BASE; DUP_GROUP=UH \
ISSUED=17-May-2009 NOTICE="This license is usable only by \
Vianova Systems AS" SIGN="1966 5675 BBC9 EA10 8FA6 EAA2 70C0 D6B9 \
551D D0E7 7154 0223 B75E C143 93E4 0191 A9C6 EE93 C623 E5B9 \
295B AE2D 6ABB 9AD2 5CDC D952 0877 B671 DCA1 1963"
The name of the license file is not important, but it must have .lic or .dat as extension.
The following table shows a short description of the various fields. For more detailed information, see the FLEXlm End User Guide.
| ServerName and Host ID |
Binds the license to a particular server. |
| VendorDaemon |
The name of the server-side Novapoint license daemon. |
| IncrementName |
Name of the Novapoint module |
| VendorName |
Name of the Novapoint vendor daemon (NOVAPT) |
| Version |
The product license version |
| ExpirationDate |
The license is valid until this date. |
| NumberOfLicense |
Specifies the number of maximum allowed users of a given license, hosted on this particular server. |
| VENDOR_STRING= |
Defines a vendor specific configuration setting. |
| DUP_GROUP= |
Defines how the server does or does not handle the sharing of multiple license requests. Default for Novapoint applications is Host and User, meaning that the same user on a given host can use multiple copies of the same license. |
| ISSUED= |
The date when the license file was generated by your Novapoint distributor. |
| NOTICE= |
An optional field used for company information. |
| SIGN= |
The encrypted signature used to authenticate the attributes of the license file. |
Make sure the formatting of the license file is as displayed above. In some configurations, line shift is not treated correctly, making the license file unreadable to the license server.
Adding extra licenses to an existing license file
Adding new licenses to an existing license file is done manually by copying the content of the new file to the existing file at the server. Copy the block from the new file starting with INCREMENT into the existing license file. Users can only add extra licenses to an existing license file in case the HOSTID is the same.
You must stop and restart the license service to make the changes take effect, using lmtools.exe. It is not necessary to reboot the server.
Existing file:
VENDOR NOVAPT
USE_SERVER
New license file received from your Novapoint distributor:
VENDOR NOVAPT
USE_SERVER
INCREMENT NP_ROAD_PROFESSIONAL NOVAPT 19.00 permanent 1 \
VENDOR_STRING=DEPENDS:NP_ROAD_PROFESSIONAL>NP_BASE; \
DUP_GROUP=UH ISSUED=17-May-2009 NOTICE="This license is usable \
only by Vianova Systems AS" SIGN="0251 8409 C323 2666 D8DA 19A0 \
9842 8A9F CB75 3361 1B00 64FC C430 AB17 3194 1D28 BFE1 5714 \
1351 705F A451 25BC 5FC5 C836 B0F4 1994 8A5A 2DCC 4058 B720"
Combined license file:
VENDOR NOVAPT
USE_SERVER
