Novapoint Road Library
How to Use It
04-20-2021 05:38
To start using the Intersection task first complete the proper installation. Also, make sure that the system settings for Novapoint are pointing to the correct *.exe-file to be able to work.
  1. Create an Intersection task with two or more alignments as input.
  2. Set a Calculation Basis. Without it, it will not produce the ditches or fills.
  3. Complete the task.
  4. Double-click on the task to start the tool. Please wait.
  5. You will see a plan view of your intersection. Edit the input as you would like.
  6. Define a pavement and ditch construction through the button [Select Structure…].
  7. Press OK to complete the tool.
  8. View the results of your Intersection task by viewing it in 3D in the Quadri model.
Here is a quick introduction to how to use the Intersection task:
3D Intersection Design 21.1
3D Intersection tool v 19.40-00
3D Intersection tool v 18.40-00
