Novapoint Road Library
Input H
04-19-2021 10:20
The table with the input data of horizontal geometry forms the base for the alignment calculation in NADB.
  • Customize the user interface by minimizing the number of tabs (Input H/V, Result H/V, Errors H/V, etc.) to be displayed in the user interface using the dialog 'Options'.
    • Double click any tab (Input H/V, Result H/V, Errors H/V, Ref. Points, History, etc.) of the user interface to open the dialog 'Options'.
  • Customize the user interface by turning off any of the columns, 'Parameter', 'End Radius', and all the columns of 'Coordinates in Input H' (E1, N1, E2, and N2) using the dialog 'Options'.
    • Double click any column heading of the tab 'Input H' or 'Input V' of the user interface to open the dialog 'Options'.
  • Every line in the table represents an element in the alignment and the first line is always the first element.
  • A common feature for all the tables is that the cells containing no input data are grey.
No. (Element Number)
  • Every element in the alignment is numbered in the calculation order in a consecutive fashion.
  • The element number can be edited by writing a new number in the number area.
  • The elements are renumbered automatically, but the requirement is that it is a positive number.
Element (Element Type)
  • There are three different element types: line, arc, and transition (clothoid).
  • These elements can be combined in a number of different combinations, but not all combinations allow for a successful calculation.
  • The different elements have colors that correspond with the colors of the design line (alignment on AutoCAD drawing).
Type (Fixation type)
  • Fixed: The element or elements extension is going between two determined fixed points (draggable).
  • Partly Fixed: The element or elements extension is going through one determined fixed point (rotate able).
  • Approximate: Floating element i.e. no fixed points on the element. Set radius and bordering elements determine the element's placement. The approximate point, which is declared by (x1, y1) is used in these cases where two mathematical solutions are present. The solution, which places the alignment closest to the approximate points, is chosen.
  • Approximate Radius: Only applicable for arcs. An arc is fixed in a declared fixed point and the arc's radius is calculated as a result of this.
  • Length: An element decided by the length. Assign the element's length in the column for length.
  • Centre:
  • For more details, refer to 'Segment Classification'.
Radius (Element radius)
  • This column displays the radian value of an element, like Arcs.
  • If the element is a transition (clothoid) this is displayed in the transitions (clothoid) starting radius.
End Radius
  • The radius of transition curve at its last chainage.
Length (Element length)
  • This column displays the length of the element at the time where this was input data for this element, in other cases, refer to Parameter.
Parameter
  • Transition curve parameter (A)
  • The transition element - clothoid – is represented by the parameter A.
  • The formula for the clothoid is A^2=L*R
  • L = Clothoids length and R = Resulting radian.
  • From the formula, it is evident that A and L is two sides to the same thing, and that theoretically it is possible to use parameters or length for one specific clothoid. In relation to road design, the parameters are used to describe the clothoid.
Arc type
  • Short or long arc
E/N (Easting/Northing)
  • The coordinates of end points of line elements.
