Novapoint Terrain Library
Insert Leader to Point Elevation
04-12-2021 12:31
Use this tool to add a prefix to point elevation.
MOUS_ICO Menu: Terrain > Elevation label>
Insert leader to point elevation
MOUS_ICO Toolbar: Elevation label: Insert leader to point elevation
Working procedure
Start the function and the command prompts:
Select point height to move:
Select point elevation - a leader will be created from insertion point to new position.
Note:
  • The leader is actually a 3D polyline.
  • To adjust the position of the point elevation and its leader - just double click on the point elevation. Note: Double-clicking, in this case, does not start the function Move point elevation x,y...
  • To remove the leader, delete it. The point elevation will then return to the correct position.
About point elevations in Novapoint Terrain
  • The leveling tools are a set of functions working within the dwg file as well as interacting with the active terrain model. Editing and calculating point elevations must be done by using the leveling tools only. It does not work to use AutoCAD functions like move, copy, copyclip/paste, properties, attribute editor, etc. in order to edit or manage the appearance of the point elevations.
