Novapoint Terrain Library
Interpolate Elevations Along 3D Line
04-12-2021 15:06
Use this function to interpolate elevations of break points of 3D lines (source line). The source line can be 3D Polyline or lines converted to 3D line using '3D - lines...'.
  • The minimum requirement is that the elevations are assigned for at least two distant break points, which are used to interpolate the heights of the intermediary break points.
  • All the breakpoints with heights will be used for interpolation.
  • Only those break points that are between the break points with heights will be interpolated.
MOUS_ICO Toolbar: Terrain design: {{}} Interpolate elevations along 3d-line
MOUS_ICO Menu: Terrain > Terrain design > Interpolate elevations along 3d-line
Command prompts for:
Select a 3D Polyline:
MOUS_ICO Pick the source line
The result is displayed at the command line. The source line will be redrawn with the interpolated heights.
Tip:
Shortcut to this function (in case the source line is a 3D-line drawn using '3D - lines...'):
MOUS_ICO Toolbar: Novapoint Base:
 object_menu
Select an Entity:
MOUS_ICO Pick a 3D-line (source line)
MOUS_ICO Select the flyout menu option 'Calculate Elevations'
Object menu (NCO)
For the associated functions of the drawn line using this function, run the function 'object_menu'.
  • For further details, refer to '3D Line'.
