Novapoint Noise Library
Layer name for Fetching Buildings
04-15-2021 16:15
There is no need to make changes in this dialog box if the map is read using the function “Draw Map from Terrain model” and buildings are defined with the following feature codes:
Feature code Type
5001, 5031 Buildings defined by roof height
5000, 5002, 5032 Buildings defined without height
5082 Building ridges
If feature codes other than those above are used for building/ridge in the terrain model, the contents of this dialog box have to be changed before buildings are fetched to Novapoint Noise.
Type
Here you select whether to change layer names for Buildings defined by roof height, Buildings defined without height, or Building ridges.
Layer names
List of the layer names in which Novapoint Noise seeks for building information, for current Type.
Choose layer...
If you click this button, a list of layer names appears, from which you select the layer name you know contains the building information of the type given under Type.
Delete
This button gives you the opportunity to delete highlighted layer name in the list “Layer names” for the current Type.
Set default
Sets the layer names in the list “Layer names” back to default for all Types.
All thawed layers
All layers in the drawing which are not frozen will appear in the list “Layer names” for the current Type.
OK
The selected layer names will become valid, and the dialog box is closed.
Cancel
The layer names that were valid as entered in the dialog box will still be valid, and the dialog box is closed.
Help...
This page.
Advanced mode
There will be necessary to change settings here if the map is read to AutoCAD using another function than “Draw Map from Terrain Model”.
Enter the desired layer name to the field Name possibly using wildcard characters (see AutoCAD's user's manual), thereafter click New to add this layer name to the list “Matches”. If you want to change a layer name in the list “Matches”, highlight this layer name which then will appear in the field Name. Here you perform the desired changes and click Change to update the list “Matches”.
